12 years agoClock Frequency Max
Hi, this may be a stupid question so I ask for your forgiveness in advance: I have an application where I have two square wave inputs at 300 MHz; I wish to measure the time delay between the r...
12 years agosince it is 300KHz then you don't need much work. you can use simple counters or state machine but I have done a design before based on the following approach:
1) register both inputs twice on your clock in1 => in1_1d => in1_2d in2 => in2_1d => in2_2d 2) run two flips one clocked by in1 and one clocked by in2 if in1 edge arrives set flip1 output to '1' if in2 edge arrives set flip2 output to '1'; and apply async reset if both these outputs are '1'; (this will be a short glitch but should do) 3) run two counters on your system clk count1 enabled if flip1 output = '1 count2 enabled if flip2 output = '1' asynchronously reset both counters if in1_2d = '1' and in2_2d = '1'; 4) assign delay as signed value if count1 > count2 then it is +count1 else it is minus count2
