15 years agoClock doubler without PLL
I have a design where I need to double an incoming frequency but lo and behold I made a mistake of not putting this input signal in a dedicated clock input pad.... so, it would appear that PLL:...
15 years agoFor a proper fpga based design, I am afraid the notion of doubling clock without pll will get you in a timing mess.
Consider using the slow clock but use two processing channels (odd/even samples). Though a pain but should be equivalent. The problem would be at final crossover to double rate... This is equivalent to having a DDR approach inside fpga.
