16 years agoClock divider
I need to have a continuous clock input to my traffic light assignment. A clock divider from 100MHz to 1Hz is needed. But I dont know how to write the code as I am new to vhdl. Anyone can help? :confused: or is there any other way I can get a continuous clock input so that I can program the code directly to the board.. ? Then the green light represented by green led wil light up for 30s, yellow for 2s..
--- Quote Start --- Hi Tricky, you are right, I should read all posts, but maybe he has now a starting point ... Kind regards GPK --- Quote End --- Hi, now the VHDL version. Maybe not the best way for VHDL, but I'm not a VHDL expert. LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.ALL; ENTITY ena_gen IS PORT ( -- Input Ports clk: IN std_logic; -- Output Ports ena_out : OUT std_logic ); END ena_gen; ARCHITECTURE RTL OF ena_gen IS SIGNAL count : std_logic_vector ( 26 DOWNTO 0); SIGNAL edge_det: std_logic; BEGIN -- Pulse counter counter : PROCESS (clk) BEGIN IF rising_edge (clk) THEN count <= count + '1'; edge_det <= count(26); END IF; END PROCESS counter; ena_out <= (NOT edge_det) AND count(26); END rtl; Kind regards GPK - Altera_Forum
--- Quote Start --- This is Verilog - he asked for VHDL --- Quote End --- Hi Tricky, you are right, I should read all posts, but maybe he has now a starting point ... Kind regards GPK - Altera_Forum
--- Quote Start --- how to use the altera megawizard.. --- Quote End --- Hi, use a counter and an edge detection in order to generate an enable signal for your register. E.g module ena_gen (clk,ena_out); input clk; output ena_out; reg [26:0] count; reg edge_det; always @(posedge clk) begin count <= count + 1; edge_det <= count[26]; end assign ena_out = !edge_det & count[26]; endmodule Kind regards GPK - Altera_Forum
It is in the Quartus menu.
Sounds like you need to have a large counter (25 bits or so) and "and" all the bits together to form an enable for other registers to give you a 1Hz clock rate.
You can use the Altera Megawizard to generate this logic for your device.
