16 years agoClock divider
I need to have a continuous clock input to my traffic light assignment. A clock divider from 100MHz to 1Hz is needed. But I dont know how to write the code as I am new to vhdl. Anyone can help? :conf...
16 years ago --- Quote Start --- Hi Tricky, you are right, I should read all posts, but maybe he has now a starting point ... Kind regards GPK --- Quote End --- Hi, now the VHDL version. Maybe not the best way for VHDL, but I'm not a VHDL expert. LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.ALL; ENTITY ena_gen IS PORT ( -- Input Ports clk: IN std_logic; -- Output Ports ena_out : OUT std_logic ); END ena_gen; ARCHITECTURE RTL OF ena_gen IS SIGNAL count : std_logic_vector ( 26 DOWNTO 0); SIGNAL edge_det: std_logic; BEGIN -- Pulse counter counter : PROCESS (clk) BEGIN IF rising_edge (clk) THEN count <= count + '1'; edge_det <= count(26); END IF; END PROCESS counter; ena_out <= (NOT edge_det) AND count(26); END rtl; Kind regards GPK
