lambert_yu
Contributor
2 years agoClock constrains for GPIO IP core of arria 10
Hi, all fpga : 10ax115N3f45I1sg quartus : 18.0.0 standard version Now I'm using GPIO IP core to design using bus lvds. And for this IP, I use half rate design, read and wirte use seperate cl...
- 2 years ago
Hi Lambert,
Probably should be fine since there's no timing violation.
Since that's asynchronous input and output so not need to set input delay and set output delay. Without set input delay and set output delay, you wouldn't see any timing violation one.
Sheng
ShengN_altera
2 years agoHi Lambert,
May I know you still got any problem with your sdc constraints?
Sheng
lambert_yu
Contributor
2 years agoHi, Sheng
Just because I designed one very simple project and there's only the instance as in the first message. And there's no timing violation. But I want to know which suitable constriants will I need to add (which I provided and related analysis is correct?) in one large project in the future. I have little confidence about this part.
BRs,
Lambert
