Clock constrains for GPIO IP core of arria 10
- 2 years ago
Hi Lambert,
Probably should be fine since there's no timing violation.
Since that's asynchronous input and output so not need to set input delay and set output delay. Without set input delay and set output delay, you wouldn't see any timing violation one.
Sheng
Hi Lambert,
I had further confirmed with my team that since you're using async input and async output (neighter system_sync nor source sync design) so not need to set input delay and output delay, just timing exceptions will do.
And because fr_clk and hr_clk comes from the same PLL output, I think "derive_pll_clock" constrain will be okay
Yes, the derive_pll_clocks constraint will take care of the clock relationships from the PLL
(1) Just because there's hr_ddio and fr_ddio, I need follow "Opposite-Edge Capture Edge-Aligned Output" to set the DDR constrians for each *_ddio part or only set the DDR constrians for only fr_ddio?
I think your mentioned situation suits well to "Opposite-Edge Capture Edge-Aligned Output" if check this document illustration https://cdrdv2-public.intel.com/653688/an433.pdf. For "Opposite-Edge Capture Edge-Aligned Output", do not use any multicycle or delay exceptions for opposite-edge transfers. The only exceptions necessary for correct timing analysis are false path exceptions.
So, set false path DDR constraints to only fr_ddio will do like example show in this link https://www.intel.com/content/www/us/en/docs/programmable/683780/22-1/full-rate-or-half-rate-ddio-output-register.html
Hi, Sheng
In AN443, in my view, I think it's for input and output interface constrains which are for the path between DDIO and pad. And for the false path exception constrains, it needs data_clock and virtual clock (for input) or output_clock (for output), and if I add virtual clock or output_clock, I think it presents system or source-sync design? I feel confused. How do you think about it?
BRs,
Lambert
