16 years agoCLKCNTRL block placement conflicting with PLL placement
I am muxing two clocks generated from the same pll using the altclkctrl block. The connections look like below -
1'b0 ---> ALTCLKCTRL.inclk[0] 1'b0 ---> ALTCLKCTRL.inclk[1] PLL_T1 - CLK[4] ---> ALTCLKCTRL.inclk[2] PLL_T1 - CLK[5] ---> ALTCLKCTRL.inclk[3] Internal Reg ---> ALTCLKCTRL.clksel[0] 1'b1 ---> ALTCLKCTRL.clksel[1] But... I get following placement error in fitter... Any suggestions as to what may be happening? TIA. Sanjay Info: CLKSELECT placement assigned the following 3 node(s) to these locations Info: Node flir_top_wrapper:flir_top_wrapper_inst|flir_top:arch_normal.flir_top_inst|pxl_clk_mux:pxl_clk_mux_inst|pxl_clk_mux_altclkctrl_fne:pxl_clk_mux_altclkctrl_fne_component|sd2 is assigned to location CLKSEL_G0 Info: Node flir_top_wrapper:flir_top_wrapper_inst|flir_top:arch_normal.flir_top_inst|pxl_clk_mux:pxl_clk_mux_inst|pxl_clk_mux_altclkctrl_fne:pxl_clk_mux_altclkctrl_fne_component|sd1 is assigned to location CLKCTRL_G0 Info: Node clk_wrapper:clk_wrapper_inst|clk:arch_normal.clk_inst|clk_pll:clk_pll_inst|altpll:altpll_component|clk_pll_altpll:auto_generated|pll1 is assigned to location PLL_L2 Error: Cannot place Top/Bottom PLL "clk_wrapper:clk_wrapper_inst|clk:arch_normal.clk_inst|clk_pll:clk_pll_inst|altpll:altpll_component|clk_pll_altpll:auto_generated|pll1" in PLL location PLL_L2, because location does not accept Top/Bottom PLLsNo RepliesBe the first to reply
