clk_pll input location for DDR4 HPS (arria10sx066f34I2SG)
- 6 years ago
Hi there,
I apologize for the late reply, due to Lunar New Year.
Please try the following:
- You will need below INIs variable :
• emif_restrict_hps_refclk_to_ac_tile=off
1. Open the fitter_error.qar file, add the INI file with emif_restrict_hps_refclk_to_ac_tile = off.
2. Then re-check the fitter.
Could you please try using these INIs and let us now if the error disappears when placing an HPS-EMIF?
2. If not, could you try using Quartus 19.1 if are you seeing the same error? Please let us know if the error the same when using Quartus 19.1.
Regards.
For HPS DDR, you have to use specific pins for a specific I/O bank since the interface is all hardened and dedicated to the HPS. If there's already a clock not used by the memory interface going into that particular pin, you'll have the issue you're seeing.
#iwork4intel
