14 years ago
Clear RAM 2-port
I created a RAM 2-port, port A for writing only, port B for reading only.
Before I write a new data into port A in RAM 2-port, I want to clear/reset all data and address in Port B first? how can I do that ?
Thanks in advance
Hung
    Well you don't need to. Just don't read until write finished i.e.check last address of write then read
    you will have to write all 256 addresses from port B to clear it. You cannot "reset" a ram.
    Because I configure Port A and Port B with different size. Port A is 1-bit data, 13-word address. Port B is 32-bit data, 256-word address for M9K. when I write new data in Port A, then access data from Port B it may be duplicated with the previous data. Therefore, before writing new data to port A, I want to reset RAM 2-port to the initial status when we just turn on the board.
    It's not clear what you mean with "clear/reset all data and address in Port B". Apparently not clearing the RAM content, which would need a sequential program anyway. The data appearing at port B will be updated according to the specified RAM behaviour. What do you want to achieve besides the default behavior?
