14 years agoclarification regarding writing testbench
I am writing a test bench for a ethernet packet generator module. I drive the input ports of my DUT using registers and declared the output as wire. I need some clarification on what signal type is to be used for the internal registers (ex in my case Ethernet configuration registers) in my testbench. thanks, manihatn1 Reply
By "internal registers", you mean signals with the TB, not the DUT, correct?
Probably, you'll want to use mostly always blocks -- thus, registers.
