18 years agoCIII / Configuration
Hi, I have a cyclone EP3C10F256C8 and configuration flash EPCS4SI8N. I have 2 of 10 boards which won't configure. All the signals are present: DCLK coming from the FPGA, CS, ASDI, and DATA co...
18 years ago --- Quote Start --- I do understand what you're saying about timing; but if your receiver doesn't have a tHOLD time of 0 then you could get into trouble. --- Quote End --- Yes, but by specification, it is zero. You should also consider, that the clock is generated by the FPGA itself. So from the FPGA internal view, the DCLK and DATA0 I/O cell delay subtracts from the setup and adds to the hold time of the receiving register. Hard to imagine, how a timing issue should arise here, assuming the internal register has a hold time comparable to other FPGA resources. I also expect an assembly problem as most likely reason.
