16 years agochose FPGA
I have a code in c + +, I work with bmp images (480 * 640), I want to implment it on a fpga board does anyone can help me to chose the correct board?
16 years agoUse the altera C2H compiler it compiles C code into hardware.
Or analize your code to find out how many multiplications and intermidiate memory you use. I did a complex image processing algorithm in a FPGA 125MHz and it run 20000 faster than a very powerfull 3GHz workstation with lots of cache. So some classes of algorithms benefit a lot from FPGA implementation. But it is hard to say how much, unless you really do it.
