19 years agochoose proggrammer
hello, someone has already used masterBlaster or usbBlaster? which of the two advised to me? thank you... Stefania:)
19 years agoStefania, with USB Blaster you can use two ways :
1. with Active Serial interface : http://www.altera.com/literature/hb/cfg/cyc_c51014.pdf (http://www.altera.com/literature/hb/cfg/cyc_c51014.pdf), see page 4-9 (MSEL0 and MSEL1 have to be tied to ground for AS). It is the simplest way. SFL is not need but you have to add AS connector to your board. 2. with JTAG interface - in this case you have to use SFL, as described in AN370 (or look at Christian's note - it is very useful).
