19 years agochoose proggrammer
hello, someone has already used masterBlaster or usbBlaster? which of the two advised to me? thank you... Stefania:)
19 years ago --- Quote Start --- You must use a usb blaster if you plan to use a stratix 2 or newer device (byteblaster cannot program it). .... --- Quote End --- It is strange. I'm use Byteblaster2 for working with StratixII without any problem. --- Quote Start --- I had an issue with the Terasic blaster, then I leave it on the jtag socket, my fpga does not start....... --- Quote End --- May be this mean that PI3VT3245 does not swithch to high impedance state. You should check an Enable signal on the pin 19 of PI3VT3245. --- Quote Start --- ... - we see the opposite behavior in active serial mode - with the Altera usb blaster ... --- Quote End --- What is revision of your Altera USB Blaster? B or C? I have developed my own USB Blaster clone :) based on EPM240. It work properly in all modes :)
