19 years agochoose proggrammer
hello, someone has already used masterBlaster or usbBlaster? which of the two advised to me? thank you... Stefania:)
19 years agoI use an USB-Blaster from Terasic.
When I program the EP2CS in active serial (Cyclone II on board) if I leave the connector, my FPGA doesn't leave the reset status. This is the only strange behavior. I use also in JTAG mode or with Signal Tap without problem. Never tried with an Altera USB-Blaster.
