19 years agochoose proggrammer
hello, someone has already used masterBlaster or usbBlaster? which of the two advised to me? thank you... Stefania:)
19 years agoHi Stefania,
You should use USB Blaster, especially if you work with QuartusII (in obsolete software MAX+PLUS II the USB Blaster is not supported). USB Blaster is newer hardware from Altera. MasterBlaster is older one. Also you can use cheapest clone of USB Blaster from Terasic. :)
