12 years agoChanging PLL settings without a new compilation
Hi, I am using Arria V GX FPGA and Quartus 13.1 and there are timing violations, so I need to try different PLL settings to try to fix them. Is there a way to change the PLL phase shift for examp...
12 years ago --- Quote Start --- Using dynamically configurable PLLs is a very powerful way to explore various configurations. So, it is well worth investing the time to get to grips with it. It becomes a very useful tool to fine tune interfaces, especially with external peripherals. If you can stomach instantiating a Nios to control it you will realise an enormous amount of flexibility. --- Quote End --- Alex, How do you analyse the results with timing analyser, or do you just accept the analysis will fail but that you can fix it by varying some PLL properties? How do you know that things are 'working' properly? I've never used dynamic configuration of anything that would affect the timing analysis but am interested in what's involved. Nial
