12 years agoChanging PLL settings without a new compilation
Hi, I am using Arria V GX FPGA and Quartus 13.1 and there are timing violations, so I need to try different PLL settings to try to fix them. Is there a way to change the PLL phase shift for examp...
12 years agoUsing dynamically configurable PLLs is a very powerful way to explore various configurations. So, it is well worth investing the time to get to grips with it. It becomes a very useful tool to fine tune interfaces, especially with external peripherals. If you can stomach instantiating a Nios to control it you will realise an enormous amount of flexibility.
However, I'm not sure I'd expect it to solve all your timing violations - assuming they're internal violations you're referring to. Shifting the phase of a clock is not going to benefit any block of logic that resided entirely on that clock domain. Are we discussing cross domain issues? Perhaps you can shed a little more light on the timing violations you have. Regards, Alex
