12 years agoChanging PLL settings without a new compilation
Hi, I am using Arria V GX FPGA and Quartus 13.1 and there are timing violations, so I need to try different PLL settings to try to fix them. Is there a way to change the PLL phase shift for examp...
12 years agoThere is a way, but it's not very simple.
If you generate the PLL with ALTPLL_RECONFIG, instead of ALTPLL you can reprogram the PLL from within the operating system. This is usually done with a CPU either inside or outside of the block, but a few canned configurations could be setup into block rams, and initiated with a state machine if you needed to test a few configurations. I suggest you read up on this: http://www.altera.com/literature/ug/ug_altpll_reconfig.pdf Regards, Pete
