15 years agoChanging data width in floating point ip vs using fixed point
I am confused in trying to differentiate among the two options: Changing the default data width(32 bits) in Altera floating point ip cores vs Using fixed point ip. Are these two things not the ...
15 years ago --- Quote Start --- The FP MegaFunction data width can't be reduced below 32 bit single precision. FP format (it's using a normalized mantissa and an exponent) is basically different from fixed point format. --- Quote End --- So, if I wanted to use fixed point arithmetic would that mean that I would have to write my own cores for all the arithmetic(+,-,/,*,exp) myself?
