14 years ago
changes in the constant parameter affecting the logic
Making some unwanted changes which is not a logical change affecting the complete logic...
For eg.. VHDL syntax
constant x : std_logic_vector(15 downto 0):=x"af11";
this value is used in my logic while transmitting a ethernet packet. if i am changing the constant parameter to any other value my logic is not working.
what could be the issue?
    Changing value of x changes the logic means obviously x is being used in the logic to affect the result. So obviously you cannot randomly change value of x without first understand what it does. You need to see where x to used and how it's used and then things will become clear.
    --- Quote Start ---
    --- Quote End ---
    A constant is meant to be there as constant for some purpose.
    You tell us why do you want to change it and what does it do?
    A constant is not variable(I believe) and is used instead of embedding numbers directly in code in various parts that makes it difficult to change for any future update or purpose.
