14 years agochanges in the constant parameter affecting the logic
Making some unwanted changes which is not a logical change affecting the complete logic... For eg.. VHDL syntax constant x : std_logic_vector(15 downto 0):=x"af11"; this value is used in my l...
14 years agoChanging value of x changes the logic means obviously x is being used in the logic to affect the result. So obviously you cannot randomly change value of x without first understand what it does. You need to see where x to used and how it's used and then things will become clear.
--- Quote Start --- Making some unwanted changes which is not a logical change affecting the complete logic... For eg.. VHDL syntax constant x : std_logic_vector(15 downto 0):=x"af11"; this value is used in my logic while transmitting a ethernet packet. if i am changing the constant parameter to any other value my logic is not working. what could be the issue? --- Quote End ---
