anonimcs's avatar
anonimcs
3 years ago
Change VHDL generic via command line for synthesis
Hello everyone,
I have a project which consists of multiple IPs. I have a qsys file for each configuration of the IPs and I also have a top-level generic that allows me to not have a duplicate of VHDL code just for having different input bit widths. My question here is that I want to configure the generic via command line (or with some scripts) but I couldn't find a way to do so. The closest thing I could find is creating project revisions, but those are not fully flexible as we need to create all project-related files before running synthesis. I was wondering if anyone could configure their generics via command line without having to copy all the project files + the vhdl source code
  • Hi,
    then how should I make the pin assignments for the pins not used when generic = 0 (they're only used when generic = 1). Is there a way to set them 'conditionally' in the qsf file ?
    For above mentioned can't be achieved in .qsf, you may need to use .tcl script if/then/else already as mentioned. For example like below in .tcl:
    set a [get_parameter -name C3_CNT]
    if {$a == 1} {
    set disable 0
    set enable 1
    } else {
    set enable 0
    set disable 1
    if {$enable} {
    set_location_assignment PIN_W28 -to outclk6 -disable -comment IOBANK_3C -remove
    set_location_assignment PIN_W28 -to outclk6 -comment IOBANK_3C
    export_assignments
    if {$disable} {
    export_assignments
    Remember that if want to enable, make sure source the .tcl twice in order to remove the previous -disable assignment.
    [Take Note This]: Critical Warning(19941): QSF command 'set_parameter' can only apply to the top-level design and cannot include '-to' or '-entity' arguments.
    If you notice that 'set_parameter' doesn't take effect, remove the '-to' or '-entity' arguments because it can only apply to top-level design.
    Sheng
  • ShengN_altera's avatar
    ShengN_altera
    if {$a == 1} {
    set disable 0
    set enable 1
    } else {
    set enable 0
    set disable 1
    if {$enable} {
    export_assignments
    if {$disable} {
    export_assignments
    Sheng
    ShengN_altera
    Sorry for confusion. The package require ::quartus::project is not needed in the previous post community.intel.com/t5/Programmable-Devices/Change-VHDL-generic-via-command-line-for-synthesis/m-p/1534942#M93067 situation. It'll only be needed when you want to project_open and export_assignments the tcl assignment like the .tcl script attached below. Btw, you can generate the .tcl script attached below by going to Project -> Generate Tcl File for Project.
    Forgot to mention that if you want to source the .tcl script in command prompt you can use this command quartus_sh -t
    sheng
    ShengN_altera
    You can add this tcl command to a .tcl file. Then go to View -> Tcl Console, in the Tcl Console type source <file_name>.tcl. Besides, can go to Tools -> Tcl Scripts and then Select and Run.
    Also, you can straightaway include that tcl command in the .qsf file.
    Sheng
    • anonimcs's avatar
      anonimcs
      Adding the tcl command directly to the qsf file is totally fine for me, but I have a follow-up question. As I mentioned, the entity's port widths are dependent on this generic, then how should I make the pin assignments for the pins not used when generic = 0 (they're only used when generic = 1). Is there a way to set them 'conditionally' in the qsf file ?
      Cheers
    • anonimcs's avatar
      anonimcs
      Looks promising, which file should I add this command to ?
      Cheers,
