Change VHDL generic via command line for synthesis
- 3 years ago
then how should I make the pin assignments for the pins not used when generic = 0 (they're only used when generic = 1). Is there a way to set them 'conditionally' in the qsf file ?
For above mentioned can't be achieved in .qsf, you may need to use .tcl script if/then/else already as mentioned. For example like below in .tcl:
set a [get_parameter -name C3_CNT]
if {$a == 1} {
set disable 0
set enable 1
} else {
set enable 0
set disable 1
if {$enable} {
set_location_assignment PIN_W28 -to outclk6 -disable -comment IOBANK_3C -remove
set_location_assignment PIN_W28 -to outclk6 -comment IOBANK_3C
export_assignments
if {$disable} {
export_assignments
Remember that if want to enable, make sure source the .tcl twice in order to remove the previous -disable assignment.
[Take Note This]: Critical Warning(19941): QSF command 'set_parameter' can only apply to the top-level design and cannot include '-to' or '-entity' arguments.
If you notice that 'set_parameter' doesn't take effect, remove the '-to' or '-entity' arguments because it can only apply to top-level design.
Sheng
if {$a == 1} {
set disable 0
set enable 1
} else {
set enable 0
set disable 1
if {$enable} {
export_assignments
if {$disable} {
export_assignments
Sheng
