anonimcs's avatar
anonimcs
3 years ago
Change VHDL generic via command line for synthesis
Hello everyone, I have a project which consists of multiple IPs. I have a qsys file for each configuration of the IPs and I also have a top-level generic that allows me to not have a duplicate of VH...
  • ShengN_altera's avatar
    3 years ago
    then how should I make the pin assignments for the pins not used when generic = 0 (they're only used when generic = 1). Is there a way to set them 'conditionally' in the qsf file ?
    For above mentioned can't be achieved in .qsf, you may need to use .tcl script if/then/else already as mentioned. For example like below in .tcl:
    set a [get_parameter -name C3_CNT]
    if {$a == 1} {
    set disable 0
    set enable 1
    } else {
    set enable 0
    set disable 1
    if {$enable} {
    set_location_assignment PIN_W28 -to outclk6 -disable -comment IOBANK_3C -remove
    set_location_assignment PIN_W28 -to outclk6 -comment IOBANK_3C
    export_assignments
    if {$disable} {
    export_assignments
    Remember that if want to enable, make sure source the .tcl twice in order to remove the previous -disable assignment.
    [Take Note This]: Critical Warning(19941): QSF command 'set_parameter' can only apply to the top-level design and cannot include '-to' or '-entity' arguments.
    If you notice that 'set_parameter' doesn't take effect, remove the '-to' or '-entity' arguments because it can only apply to top-level design.
    Sheng
