17 years agoChange path name in qsf to sdc
Hi I tried to change path name in TimeQuest's Summary. so I used "set_instance_assignment -name" in qsf. Like that. set_instance_assignment -name CLOCK_SETTINGS WR_CLK -to ip_clk # WR_C...
17 years agoYou can use a Tcl variable:
set fast_clk {pll|altpll_component|pll|clk[1]} Then use the variable like so: set_input_delay -clock $fast_clk ... You might have to work with it a little to get wildcards like the average_calc example. Also, for exact names, TimeQuest doesn't need the entity name. Notice that the PLL name doesn't do entity_name:instane|entity_name:instance|... for each hierarchy, and instead just does the instance name between pipes. I don't think you can mix this nomenclature with wildcards though, but not certain.
