19 years agoCHANGE_EDREG JTAG instruction via a JAM file
AN357 mentions the ability to test the CRAM CRC error detection circuitry by passing a CHANGE_EDREG JTAG instruction via a JAM file. Anyone knows where I can find more details on the implementation ...
18 years agoHello,
This jam file is generated outside of Quartus so you will have to use the Quartus_jli.exe utility in your Quartus install directory or use the jam player. You can download the Jam player at the link below. https://www.altera.com/support/software/download/programming/jam/dnl-player.jsp Action program or configure are not available for this file. The action for this file is CONFIG_IO. Good luck!
