19 years agoCHANGE_EDREG JTAG instruction via a JAM file
AN357 mentions the ability to test the CRAM CRC error detection circuitry by passing a CHANGE_EDREG JTAG instruction via a JAM file. Anyone knows where I can find more details on the implementation ...
18 years agoHi,
I'm trying to generate .jam file to modify CRC checksum with the following file : crc_error.jam --------------------- NOTE "DEVICE" "EP2S30"; NOTE MAX_FREQ "10000000"; ACTION CONFIG_IO = EXECUTE; PROCEDURE EXECUTE; BOOLEAN X = 0; DRSTOP IDLE; IRSTOP IDLE; STATE IDLE; IRSCAN 10, $015; DRSCAN 32, $FFFFFFFF; STATE IDLE; EXIT 0; ENDPROC; ' END OF FILE CRC 19a6; --------------------- Quartus II Programmer send back the following message style for the previous crc_error.jam file and from the generated Quartus II MyFGPA.jam file (generated from .sof) : "Error : programming error : multiple files specified for Programmer" The JAM player doesn't support DO_PROGRAM or PROGRAM action for the crc_error.jam file My configuration is built as follow : - Stratix II EP2S30 with EPCS64 - .JIC file built from .SOF file How can I generate properly .JAM file for EP2S30 and which software can I use to change CRC value on Stratix EP2s30 ? Thanks a lot
