19 years agoCHANGE_EDREG JTAG instruction via a JAM file
AN357 mentions the ability to test the CRAM CRC error detection circuitry by passing a CHANGE_EDREG JTAG instruction via a JAM file. Anyone knows where I can find more details on the implementation ...
19 years agoYou can use the JAM file below.
Using the JAM file, modify line# 9 to an arbitrary number. This is to change the CRC checksum value. DRSCAN 32, $FFFFFFFF; This will overwrite the CRC checksum in the Storage Register through CHANGE_EDRED instruction. CRCERROR pin will then go high, signaling a CRC error. --Jam file-- NOTE MAX_FREQ "10000000"; ACTION CONFIG_IO = EXECUTE; PROCEDURE EXECUTE; BOOLEAN X = 0; DRSTOP IDLE; IRSTOP IDLE; STATE IDLE; IRSCAN 10, $015; DRSCAN 32, $FFFFFFFF; STATE IDLE; EXIT 0; ENDPROC;
