9 years agoChange Bar's size in PCIe Simulation
Hi guys!!:) Well, I'm trying to simulate a PCIe communication and I have the next trouble. I'm using a Cyclone V Avalon MM and with Qsys I've added a PIO. Well, Qsys setup the bar's size...
9 years ago --- Quote Start --- rsefton Please, Could you tell me how to issue from your PCIe's interface (PCIe Avalon MM interface) to PCIe link (outside from interface)??? Do you set Tx interface or any register?? Thanks for reply --- Quote End --- Yes, the Tx interface is used to initiate transactions on the PCIe bus. If I understand what you said above, you have the BAR0 master AVMM interface connected to the Tx slave interface (through a AVMM master translator)? What are you trying to accomplish with that?
