9 years agoChange Bar's size in PCIe Simulation
Hi guys!!:) Well, I'm trying to simulate a PCIe communication and I have the next trouble. I'm using a Cyclone V Avalon MM and with Qsys I've added a PIO. Well, Qsys setup the bar's size...
9 years agoThanks for reply!!
I've followed your advice and it works!!...... thank a lot!! Well, I've got you another questions about your method. 1.- When you issue a PCIe's TLP you catch the data in RxmWriteData ??? I ask you this because I'm trying to simulate a PCIe communication using Qsys' Test bench make me. There is a file where I can set a PCIe's TLP and issue it to my endpoint. Inside of that file the test bench issue a TLP to write a memory and next read that memory. I've issued next data 11111110000000000000000000000011 I should watched in RxmWriteData my data, but I can't watch it (I watch another datas). But when I read data from my memory I can watch it (I watch it in RXMReadData). Futhermore, my test bench tells me by Modelsim's console "Target Write and Read compared okay", So I think that I've issued my data correctly, but I don't know why RxmWriteData doesn't show my data.
