16 years agoCapturing values during simulation with ModelSim
Hello, I am using ModelSim to simulate a VHDL code. Is there any way to capture values of certain signals during this simulation? I was thinking about a get command in the command line, or...
16 years ago --- Quote Start --- Thanks dipling! I think in my case loggers are okay, because I just need the data so another program can handle that. --- Quote End --- You still did not tell me what you want/can use? Verilog, SystemVerilog, PSL? How are you coding your design? VHDL? In this case PSL should be used. Verilog or SystemVerilog? Use builtin fwrite functions. I may help you with an example if I know what you need.
