8 years ago
can't see enough FMAX
hello
I create one FPGA project with CycloneV( 5CGXFC9E6F35C7 ).
it has 80 pairs of LVDS inputs as DDRIO input.
when I compile the project, it says FMAX is 103MHz that is too slower than I expected.
I need 300MHz.
I tried to compile each 8bits LVDS inputs independently.
then I found that some of them is 260MHz FMAX ( that still not enough by the way. )
the other hand, some other is 103MHz FMAX.
why LVDS input has different FMAX?
I mean this big difference.
do I miss something?
thank you.
    hello sstrell.
    thanks for your answer.
    actually, I do not know SDC file well.
    I just wrote those.
    for 300 MHz clock is this.
    create_clock -name {lvdsclk300} -period 3.333 -waveform { 0.000 1.666 } [get_ports {cam_clk[3]}]
    and also for delay, I wrote this statement for pins cam_data[0] to cam_data[79]
    set_input_delay -add_delay -clock [get_clocks {lvdsclk300}] 0.000 [get_ports {cam_data[0]}]
    What do your SDC timing constraints look like? How is your clocking set up in your design. More details needed here.
