9 years agoCan't recognize silicon ID for device 1
I designed FPGA Board using Cyclone V Device and EPCQ512 programming. When program the device using .sof it loads successful and output is also correct. But when i try to program using .ji...
9 years agoMissed to tell which Micron flash has been used.
If flash verifies O.K. but configuration isn't accepted by FPGA, either wrong settings in Programming File Conversion Tool or MSEL bits must be expected. Checking for error during configuration load (nSTATUS and CONFIG_DONE signaling, how many bits are read from the flash) is interesting nevertheless.
