9 years agoCan't recognize silicon ID for device 1
I designed FPGA Board using Cyclone V Device and EPCQ512 programming. When program the device using .sof it loads successful and output is also correct. But when i try to program using .ji...
9 years ago"Error: Can't recognize silicon ID for device 1. A device ID is different from the JTAG ID. Verify that all cables are securely connected"
1).jic file is not loading in EPCQ512. 2) Loaded in Micron device, but not shows correct output. Need solution for this older issue.
