9 years agoCan't recognize silicon ID for device 1
I designed FPGA Board using Cyclone V Device and EPCQ512 programming. When program the device using .sof it loads successful and output is also correct. But when i try to program using .ji...
9 years agoI can't read the text on the images you've posted. However, it looks like it's reporting that it can't recognise one of the devices. Is this the same issue as when it 'works' with the Micron part?
--- Quote Start --- the output is wrong --- Quote End --- By this, do you meant the FPGA is not doing what you expect having booted from the EPCQ? Cheers, Alex
