EBoln
6 years agoCan't pack to I/O pin
I have two inputs (TMDS_DATA and TMDS2_RX_DATA) When I directly pass to the output the input everything works without any problems. But if I insert scaler between then the register at one input is no...
KhaiChein_Y_Intel
6 years agoHi,
Can you try to remove the user-defined location setting for the TMDS_DATA[1] node?
EBoln
6 years agoDo you mean pin assignment? Should fitter put input elsewhere?
