"Can't lunch ModelSim-altera simulation software"
On Quartus-lite (free) software on Centos7, the previous message (MGLS_LICENSE_FILE points to the ...) was due to missing 32bits libraries.
The problem has been solved using: 1) yum install glibc.i686 2) yum install libX11.i686 --setopt=protected_multilib=false 3) yum install libXext.i686 4) yum install libXft.i686 --setopt=protected_multilib=false 5) yum install ncurses-libs.i686 Best RegardsHello,
I was experiencing this same problem and thus getting the:
"Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. "
error message while trying to run the Modelsim Altera simulator which comes with the Quartus 16.1 standard edition.
The solution proposed in the above post:
"1) yum install glibc.i686 2) yum install libX11.i686 --setopt=protected_multilib=false 3) yum install libXext.i686 4) yum install libXft.i686 --setopt=protected_multilib=false 5) yum install ncurses-libs.i686 "
worked fine for me!
Thank you!!
đ đ
