9 years ago"Can't lunch ModelSim-altera simulation software"
Hi, I installed Quartus Prime 15.1 standard Edition with floating license file and which is valid. When I compile the RTL simulation it gives a pop up "Can't lunch ModelSim-altera simulation softw...
9 years ago --- Quote Start --- Thanks but the path is perfectly linked with the executable file. i format my pc and install a fresh copy of ubuntu and fresh copy of Quartus Prime standard edition 15.1. but the same problem is showing up. Is there any other possibility? Thanks. --- Quote End --- I've got the same issue with Quartus-lite/16.1.0.196 on Centos 7 The message is: Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Error: NativeLink simulation flow was NOT successful The default Eda Tools Option is /<...>/Quartus-lite/16.1.0.196/linux/x86_64-linux/modelsim_ase/linuxaloem All seem to be correct according to this post. Do somebody help us to solve it. Best Regards
