Oliver_I_Sedlacek
Contributor
3 years agoCan't compile example Cyclone10 GX projects in Quartus Prime 23.1 Pro
To get off the ground with my shiny, new (and expensive) Cyclone 10 GX development board I went to https://www.intel.com/content/www/us/en/design-example/714945/cyclone-10-gx-pcie-gen2-x4-dma.html an...
- 3 years ago
Hi Oliver,
I don't see any report. However I am recalling a known issue, do you receive the same Internal Error: Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176Could not load pdb file - e:/quartus/quartusprimepro23.1_installed/devices/20nm/ddb_nightfury_timing_corner_db
Do you have only Cyclone 10 GX device installed? If yes, the current workaround in 23.1 is to install Arria 10 device, or you may use 22.4 instead.
Nurina
FvM
3 years agoI can compile top_23_1_0_115.qar in QPP 22.4 and 23.1, both Windows. 22.4 de-archiver complains about wrong Quartus version, but the project is unpacked and can be opened.
