Can't compile example Cyclone10 GX projects in Quartus Prime 23.1 Pro
- 3 years ago
Hi Oliver,
I don't see any report. However I am recalling a known issue, do you receive the same Internal Error: Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176Could not load pdb file - e:/quartus/quartusprimepro23.1_installed/devices/20nm/ddb_nightfury_timing_corner_db
Do you have only Cyclone 10 GX device installed? If yes, the current workaround in 23.1 is to install Arria 10 device, or you may use 22.4 instead.
Nurina
Hi Oliver,
It crashes without showing any messages?
Which OS are you using?
Can you also confirm you have the minimum disk space:
Minimum Disk Space for Intel® FPGA Software
- Intel® Quartus® Prime Pro Edition Design Software (40-145 GB)
Nurina
- Oliver_I_Sedlacek3 years ago
Contributor
Windows 10 Professional 64 bit, 669 GB free. There is no message from the main Quartus window, what it does is throw up a crash reporter. I've pressed the 'Submit report' most times but I've no idea what that does. At the top of this thread I've posted in what I see if I click on the 'Preview report'.
