Oliver_I_Sedlacek
Contributor
3 years agoCan't compile example Cyclone10 GX projects in Quartus Prime 23.1 Pro
To get off the ground with my shiny, new (and expensive) Cyclone 10 GX development board I went to https://www.intel.com/content/www/us/en/design-example/714945/cyclone-10-gx-pcie-gen2-x4-dma.html an...
- 3 years ago
Hi Oliver,
I don't see any report. However I am recalling a known issue, do you receive the same Internal Error: Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176Could not load pdb file - e:/quartus/quartusprimepro23.1_installed/devices/20nm/ddb_nightfury_timing_corner_db
Do you have only Cyclone 10 GX device installed? If yes, the current workaround in 23.1 is to install Arria 10 device, or you may use 22.4 instead.
Nurina
Nurina
3 years agoHi,
Have you tried the above solution?
It works from my end.
Nurina
