Can't access JTAG Chain
For pin connection, please refer to pin connection guidelines for cyclone V.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
Meanwhile, have you installed the driver properly? Is it detected in Quartus Programmer?
Thanks for your response.
Design is built based on the pin connection guidelines for cyclone V only. with the same design, earlier we fabricated boards & programmed through USB blaster. With the same design we re-fabricated the board & try to dump the program. We are facing this problem. We checked the all the voltage levels & assembly process also. Everything is good.
USB blaster program driver is properly installed & it detect on Quartus programmer.
kindly help me close this issue.
