MDARG
6 years agoCannot program the FPGA on the Intel Cyclone 10 GX Development Board
Hi all! When I try to program the Intel Cyclone 10 GX on the Cyclone 10 GX Development Board, I always get the Error message: "Can't configure device. Expected JTAG ID code 0x02E120DD for device 2,...
sstrell
6 years agoIn the Quartus Programmer, do you see the device in the chain? If you do an auto detect does the device appear? Also double-check all the board DIP switches to make sure you haven't inadvertently adjusted something that would cause issues with the JTAG chain.
If you open a Nios command shell (normal installed with Quartus, access from Start menu) and type "jtagconfig", what do you see, before and after you get in this state?
#iwork4intel
