Cannot program QSPI memory through ASMI Parallel II IP
- 3 years ago
We have a FIX!
We replaced the ASMI II IP with Intel FPGA Generic QUAD SPI Controller II Core, which also supports our specific Flash device, and succeeded to write to the Flash memory.
Avi
Hi Wincent,
We didn't solve the problem yet.
What I meant is that I am not sure that we need to include the Serial Flash Loader IP, since we already able to perform some Flash operations by just using the ASMI II IP, like reading from it, changing its status registers, and even erasing it (what means that the write enable bit was enabled), etc. But direct data write is not working for us. So, the QSPI pins must be toggled by the ASMI II IP during the operations that do work. I assume that the SFL is already embedded in the ASMI II IP.
So, my question was if you still think that we need to include the SFL in our design?
Thank you
Avi
Hi Avi,
If the SFL is load and can perform all the needed function (without any error),
you may exclude it from the design.
Let me know if you need any further clarification.
Wincent_Intel
