Ourspalois's avatar
Ourspalois
3 years ago
cannot program my apollo agilex SOM board
I am trying to program an apollo agilex board.
In doing so I have the problem of setting the VID assigments of the card.
(I could not find any documentation from terasic on the correct VID settings so I had to find them in examples projects, so I am not a 100% sure they are right)
so here are my settings :
set_global_assignment -name USE_PWRMGT_SDA "SDM_IO0"
set_global_assignment -name USE_PWRMGT_SCL "SDM_IO12"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE "Other"
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS "4F"
set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "400 KHZ"
set_global_assignment -name PWRMGT_VOLTAGE_OUTPUT_FORMAT "LINEAR FORMAT"
set_global_assignment -name PWRMGT_LINEAR_FORMAT_N "-12"
set_global_assignment -name PWRMGT_TRANSLATED_VOLTAGE_VALUE_UNIT "VOLTS"
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE "ON"
set_global_assignment -name PWRMGT_PAGE_COMMAND_PAYLOAD "255"
they all seem to be legal, but running my quartus synthesys I get these errors :
quartus_syn integnano_pinaipple_pinaipple_system_0
Error (22819): The option assigned for assignment (USE_PWRMGT_SDA : SDM_IO0) is not supported.
Error (22819): The option assigned for assignment (USE_PWRMGT_SCL : SDM_IO12) is not supported.
This is weird to me since I am running quartus prime pro 22.4.0 (which is not that old) and the configuration page for agilex says thoses SDA and SCL configs are allowed :
https://www.intel.com/content/www/us/en/docs/programmable/683373/current/configuration-pin-parameters.html
I will try installing quartus 23.1 to solve this issue.
Is there something I am doing wrong here ?
Many thanks
  • Hi there,
    Your setting of "SCL" and "SDA" seems be reversed. SCL for IO0 and SDA for IO12~
  • WZ2's avatar
    WZ2
    Hi there,
    I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
    Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
    Thank you for your time and cooperation.
    WZ
  • Ourspalois's avatar
    Ourspalois
    I was indeed too tired to notice ^^'
    sorry for the useless thread and thanks you for the response.
  • WZ2's avatar
    WZ2
    Hi there,
    Is it solved~
  • WZ2's avatar
    WZ2
    Hi there,
