Cannot Find Target Connection Tab In Run Configurations
Hi . I Am Entirely New To Nios 2 Ide. I Began To Perform " My First Tutorial On Nios 2" And I Got Stuck At Run As Nios 2 Hard Ware Step. In The Tutorial It Was Given That If Not Found That Option Refer To Target Connection Tab . But Where Is It?
Can U Please Help Me5 Replies
I encoutered the problem after installed Windows 7 32, too.
Using the method as follows, I solved this problem. 1. Open C:\Altera\91\nios2eds\bin; 2. Change the eclipse-nios2.exe compatibility mode to Windows Vista SP2 or low version, illustrated as the picture attached. - Altera_Forum
i figured that its the problem with os which was win 7 x64. i used on xp 32 bit and found nios hardware
I Cant Find Nios Hardware Option Any Where. In Run Config And In Run As
You can try to click the green "play" arrow while your main C-file is active (I normally go that way) or try from the menu "run" -> "run_configurations" there select "NIOS Hardware" and create new by right click. When you then go into this new configuration there is the tab "target connection".
