16 years agoCannot Find Target Connection Tab In Run Configurations
Hi . I Am Entirely New To Nios 2 Ide. I Began To Perform " My First Tutorial On Nios 2" And I Got Stuck At Run As Nios 2 Hard Ware Step. In The Tutorial It Was Given That If Not Found That Option Ref...
16 years agoYou can try to click the green "play" arrow while your main C-file is active (I normally go that way) or try from the menu "run" -> "run_configurations" there select "NIOS Hardware" and create new by right click. When you then go into this new configuration there is the tab "target connection".
