DAndr6
8 years agoCannot configure stratix 10 device with provided bitstreams
The Board Test System (BTS) is able to detect the Stratix 10 FPGA. When we set the the load selector switch (SW3.3) to ON and connect the board to the internet, the factory default design seems to ...
Nooraini_Y_Intel
8 years agoHi DAndr6,
Which configuration mode do you want use? JTAG or ASx4 or AVSTx16? You can still set the MSEL to JTAG or ASx4 or AVSTx16 to configure the Stratix 10 when power up. You just need to be careful on the power supply connection that need to be setup since you want to use PCIe application. Refer to chapter 3.1. Applying Power to the Development Board form the user guide. https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-s10-fpga.html
Note: When operating as a PCIe add-in card, the board will not power on unless power is supplied to J26 and J27.
Nooraini
