Rleduc
3 years agoCannot assign clock signal to XCVR bank pin - Arria 10
Hello dear community,
I am currently using a Terasic HAN Pilot Plateform (Arria 10) for receiving high speed data from ADC at a rate of 5 Gbps, as well as transmitting the sampling clock of 250 MH...
FvM
3 years agoIf I understand right, you want to send 250 MHz clock through SFP port. That's not directly possible by connecting a PLL, however you generate a bit sequence by oversampling with 500 MHz or 1 GHz clock.
- Rleduc3 years ago
Thank you for your response.
Yes I guess this is the way to go, however transceivers in Arria 10 is something pretty new to me and I'm not sure exactly how to take it. Is there a kind of serializer IP in Quartus where I can input my "clock data" ? Is oversampling a common method for this kind of matter ?
Regards- FvM3 years ago
yes, there's a serializer IP. Oversampling is also mentioned in the device handbook for achieving bit rates between 125 and 1000 Mbps.
